I am looking to see a sample .NET project which compiles to a DLL file instead of an EXE file. I see most of sample projects in this forum are standable applications. Robot allows to load either EXE or DLL file in the Add-ins Manager dialog. If I want to load my add-in DLL file, which is an entry point to get called when I click on my add-in name in the Add-Ins menu.
I guess my main class should inherit from a Robot interface to specify this class library is a Robot add-in. Then override an entry point method to put my code inside.
Solved by Rafal.Gaweda. Go to Solution.
