Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Movement joint
4 REPLIES 4
Dzianis.Hk
970 Views, 4 Replies
Movement joint
Hello!
How can I correctly implement in Robot the movement joint like this one?
The first one
The second one
Thanks a lot!
4 REPLIES 4
t.sautierr
in reply to: Dzianis.Hk
Releases at the edges of the panels.
If you want to model friction effect, then non linear release but you will go for a non linear analysis as well.
Don't forget to turn on dsc algorithm in the job preference.
Dzianis.Hk
in reply to: t.sautierr
Thanks for the response,
I want tio take into account in the calculation the eccentricity in tne wall and in the beam.. How can I do it?
Regards
Denis
Artur Kosakowski
Thanks! It helped
