Hi there
I have a structure, image below, that is to be cladded with alluminium sheets.
I am trying to calculate it's dynamic response and I would like the alluminuim cladding to contribiute to the stiffness however I am not interested in the stresses in the sheet itself.
As you can see below I have cladded part of the structure however when I calculate the model it creates a mesh and I end up getting this message (attached) if I clad the whole structure.
If i am not mistaken if I am not interested in the plates stresses then I shouldn't have to create the mesh to apply a stiffness.
I found this dsicussion which seemed to have a solution but amazingly I just couldn't find the "panel calculation model" text box.
Can somebody please help.
I have attached my model with no cladding in case it helps.
Solved by Rafal.Gaweda. Go to Solution.
Solved by kyp321. Go to Solution.
You can access the rigid diaphragm as shown above. The model you attached has no panels defined so could not see the error! please take a screenhot of the error and post just as an 'FYI'! Hope this helps
Yep my version of robot doesn't have this.
Can you think of another way i could model in the stiffness of the plate?
Hi
Yeah the FE is available in the version i Have (Robot Millenium 21.0.0.2810)
However if I try and include all the panels I get this message
I can model up to about half my panels by manually splitting the mesh into a 3x3 grid.
can anyone think of a way of modelling in the stiffness of these plates using this version?
For you task mesh panels with 1-2-3 FEs on each panel. Enough to give stiffeness to structure.
