Modeling of Raft
1 REPLY 1
kyp321
640 Views, 1 Reply
Modeling of Raft
I am modeling a raft  foundation in robot using non linear springs and my model will not converge... I have set a spring limit of 700kN and have checked my vertical equilibrium! Also, I have tried to run a model without limits but it will still not work! Can you help me ?
I am trying to simulate the effect of ground anchors tension capacity (when spring graph is positive) and the bearing pressure of the soil (when spring graph negative).
The results I am trying to achieve are :
1) maximum load on anchor supports
2) the redistributed moment in the slab given the anchor displacements.
Regards
Kyp
(model too large to attach)
1 REPLY 1
Artur.Kosakowski
in reply to: kyp321
Try to set the parameters as shown below:
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
