I am modeling a raft foundation in robot using non linear springs and my model will not converge... I have set a spring limit of 700kN and have checked my vertical equilibrium! Also, I have tried to run a model without limits but it will still not work! Can you help me ?
I am trying to simulate the effect of ground anchors tension capacity (when spring graph is positive) and the bearing pressure of the soil (when spring graph negative).
The results I am trying to achieve are :
1) maximum load on anchor supports
2) the redistributed moment in the slab given the anchor displacements.
Regards
Kyp
(model too large to attach)
Solved by Artur.Kosakowski. Go to Solution.
Try to set the parameters as shown below:
