in the name of GOD .
hello
how can I model an elliptical section in Robot ?
please attach an image for your answer.
very thanks beforehand.
Solved by Artur.Kosakowski. Go to Solution.
Solved by mpcloob. Go to Solution.
You can create a section of an arbitrary shape using the Section Builder module of Robot. There you can either draw its shape or import it from dxf file.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
where is "section builder" in robot ? please give me this path with image.
very thanks
Please check: http://help.autodesk.com/cloudhelp/2015/ENU/Robot/files/GUID-7D345A3C-0AB0-4077-987D-3B1C70CC33EC.ht...
thanks.
2 questions:
1 ) can i draw an elliptical section in "section definition" module without import dxf file ?
2 ) can i fill parameters in attached image in robot instead of draw section in "section definition" module ?
Yes, you can.
http://help.autodesk.com/view/RSAPRO/2015/ENU/?contextId=HIDD_RSEC_POLYLINE
Yes, you can. In such case you will not see the real shape of a section but the static calculations can be performed as or any other section.
thanks.
answer 2 is ok but in answer 1 i don't know how to draw an elliptical section with certain "a" and "b" of ellipse equation ? (see image).
please draw an ellipse in "section definition" module of robot and attach for me file or image of that.
very thanks.
You need to approximate it with straight segments.
thanks.
therefore it's impossible to draw ellipse exactly. yes ?
if i draw an ellipse in autocad and convert it's format to "dxf" and import dxf file to "section definition" module, is this method the best method for draw an ellipse in robot ?
They are similar. The shape from dxf will be divided into number of straight lines too.
