I'm trying to find a way to model a curved roof which would consist of several bended I-section beams. I would try Object Bending option however I cannot see such an option in the Edit menu (please see the attachment) eventhough the Solid Modeler is enabled.
I guess I can use the option Extrude Along Polyline however I don't prefer to bother with solids when there is a chance to use I-sections and analyse in Steel Design.
Can someone please tell me why the Solid Modeller options below Face offsetting as in the following link are missing for my version (I'm using RSA2013)? Also any ideas about how to model a curved roof under these circumstances are welcome.
P.S.: I tried both with Volumetric Structure Design and Shell Design Modules, no results.
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-6D12CC11-17B2-41B6-AD0D-2151F7D0935-418.htm
Thanks.
Solved by Artur.Kosakowski. Go to Solution.
in the name of GOD .
hello luzer
for modeling roof above your shape you should go to shell design in the first step and then follow numbers in attached image1 and then image 2.
if you can model a roof above your shape plaese prees button 'Accept as solution' below my answer.
Could you attach the sketch of your roof?
In general any curve shape of a beam should be approximated by number of straight bars. You can use the steps shown below:
Sorry I don't have any sketches of the model but the section view would look like your attached example. However if I model the roof that way, would the bending strenght of the whole beam overestimated because of the lenght of the each segment? As far as I know, Robot would analyse each segment by itself. For example if the whole beam is 30m in length and is divided into 10 parts, the bending moment would be applied onto 3m segments and bending strength would be found that way which would not reflect the exact reality. The only way to examine this kind of a model would be looking at the displacements of the nodes.
Your comments would be appriciated.
You can create a superbar (new member) for the steel design procedure that includes all the straight segments of the arch.
That will satisfy my question, thanks a lot. For those who are looking for "superbar",
http://208.74.205.69/t5/Autodesk-Robot-Structural/Probl%C3%A8me-de-mod%C3%A9lisation-steel-design/td... (message 9, the attachment)
And do you have any ideas about why Object Bending option does not appear on the Edit menu?
I'm sorry but I'm not sure if I understand you correctly. I'm not aware of any 'bending option' for bar elements.
"The current version of Robot lets you perform the following operations on objects using Solid Modeler:
The quote is from the following link,
This doesn't apply to linear elements (bars). The key word is solid
Yes but still the command doesn't show up even in the volumetric structure design module eventhough an object is sellected as you can see in the attachment of my first message. I don't use the solid modeller too often but just curious.
Some of these options are available only for Robot versions manufactured by Robobat prior to its acquisition by Autodesk. They depend on the version of ACIS geometrical kernel.
About Cone Roof, Please show me how i can model cone roof with Truncated Cone form!
So I am analysing a penstock reducer, which is basically a pipe that has a square openeing 2mx2m at one side and a circle 1.6m diameter in the other side and this pipe is 4m long.
since the face skinning (lofting) is not available in RSA now, does anyone know how to model that with refined FE size?
this pipe is burried with soil load on top in one load case and water pressure from inside as another load case.
Thanks.
