Discussion Groups
Robot Structural Analysis
Valued Contributor
sergey.churilov
Mode shape vectors
542 Views, 13 Replies
04-26-2012 03:29 AM
Hi to all,
How do you present mode shape vectors from each mode after performing modal analysis?
I would like to compare the mode shape vectors from numerical analysis with experimental analysis and establish the Modal Assurance Criterion (MAC).
Please use plain text.
Valued Mentor
tony.ridley
Re: Mode shape vectors
04-26-2012 03:38 AM in reply to: sergey.churilov
Do you mean the mode shape diagram?
Or a numerical representation?
Valued Contributor
sergey.churilov
04-26-2012 03:44 AM in reply to: tony.ridley
Numerical representation with values.
Product Support
Artur.Kosakowski
04-26-2012 04:00 AM in reply to: sergey.churilov
Press the RMB on the table with results of modal analysis and select table columns. Switch to the Eigenvectors tab.
Artur Kosakowski
New Member
murali3131
09-18-2012 05:01 AM in reply to: sergey.churilov
i didnt undesrstand what is RMB .in modalanalysis environment i am getting only frequency results. i cant see any table. i need to have mode shape vectors .kindly help me with this
Product Support
Rafal.Gaweda
09-18-2012 05:07 AM in reply to: murali3131
RMB - right mouse button
Click on table using  right mouse button then select Columns....
Rafal Gaweda
New Member
murali3131
09-18-2012 08:51 AM in reply to: sergey.churilov
i am working in autodesk inventor for modal analysis.i got first 10 modes.but i need to have mode shape vectors to compare with experimental results.i am attaching image of my result.please suggest looking at the figure.
Product Support
Rafal.Gaweda
09-19-2012 12:29 AM in reply to: murali3131
This is Robot forum, not Inventor.
Inventor http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
Rafal Gaweda
Valued Contributor
oyvinkle
01-11-2013 05:33 AM in reply to: Rafal.Gaweda
To vertify my structure i have used matlab and plottet the eigenvectors. I am trying to compare the results from robot with the results from matlab. is there a smart way to get the eigenvectors ou from robott.. all i seem to get are -0 +0 and  1 -1 ?
Valued Contributor
oyvinkle
01-11-2013 05:39 AM in reply to: oyvinkle
I was also wondering if Robot take into acount crackling of the concrete by code reduction factors for shear and flexular deformation when preforming a modal analysis?
