Hello, the modal analyis took over 3 hours and it still running, is it normal ?. i have only 39707 nodes.Thanks for help
File please.
I have one instability Rz n node 176 , btw I can't find this node.The file is attached.
I'm looking for 100 modes (modal massse > 90%)
Lack of file
Try:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Sending-bigger-files/td-p/3795062
I have one instability Rz in node 176 , btw I can't find the node :s. I m searching for 100 modes ( modal mass >90%).
the link:
I was trying to apload it from an a hour ago, thank for the trick.
I really apreciate your help
Ok so where can I change the solver type? the instability wouldn't be a problem?
In JOb Preferences \ Structure Analysis.
One remark - you have to perform calculations of 200 modes, maybe more, I do not know yet , because there are "cantilever" columns (56 112 152 153 164 549 551 559 560 563to569 571 753to760 762to769 775 867) generating many local modes without significant mass percentage.
I cant get the results now I have an error message " données incorrectes N°d'erreur 5000"
I followed the steps in the link below means that I renamed the file but it doesn't work. I had the same error : incorrect data
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14691229&linkID=12305695
Please update your robot with Service Pack 4 for v.2013 then check.
Thansks so much it worked but with a 8 core processor it take a litle bit more than 1h .I have a question : for the modale analysis I should add the masses to the 1-dynamic mass2-global mass or 3-modale case ? Thanks again
print screen is attached
