I am having problems with the results reported by RSPA2013 after a modal / spectral analysis of a structre. The tension only members do not report any axial forces for the modal/spectral analysis case. However, a simliar static lateral load case does report tension in the members. Any ideas?
Solved by Artur.Kosakowski. Go to Solution.
Please search the forum for the other already existing topic that cover non linear analysis (tension only bars) and seismic / spectral one. Thank you.
