Missing Eigenvalues execution problem: 3240
7 REPLIES 7
Message 1 of 8
1590 Views, 7 Replies
I am trying to carry out a modal analysis or a simple truss bridge.
When carrying out the modal analysis I get the message: 'Number of missing eigenvalues found = 3'
If I select cancel (to search for all modes), I get the error message 'execution problem: 3240'. Then ROBOT crashes.
I have ticked the 'Sterm check' button for the modal analysis.
I have allowed a very large number of iterations (30000).
Is there anything else I can / should be doing?
Selecting 'No' on the 'Number of missing eigenvalues found = 3' message box runs the analysis fine. What is the implication for not searching for missing eigenvalues?
Thank you for your help.
Stuart
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
Turn off Sturm Check in Modal analysis.
If it does not help please send us model.
Rafal Gaweda
Message 3 of 8
in reply to: Rafal.Gaweda
Turning the Sterm check off worked. Thank you.
out of interest why would the Sturm check algorithm cause ROBOT to crash while checking for skipped eigenvibrations?
Stuart
Message 4 of 8
Rafal.Gaweda
PLease send us model to check.
It should not crash.
Rafal Gaweda
Message 5 of 8
Rafal,
Please find attached the ROBOT model which crashes when I have the 'Sturm Check' box ticked.
It runs fine when the 'Sturm Check' box is not ticked.
Stuart
Message 6 of 8
Rafal.Gaweda
With Sturm check you can caclulate 97 modes without any problems.
Why do you need more? In fact first 4 modes are global modes, I guess the most interesting ones.
Rafal Gaweda
Message 7 of 8
Good point!
I was trying to achieve 90% MEM participation in each direction and we are interested in frequencies upto 33Hz. Infact 97 modes should be fine.
Stuart
Message 8 of 8
Rafal.Gaweda
33 modes is enough
101 modes with sturm check and press NO as answer for enlarging number of modes... or turn off sturm check.
Rafal Gaweda
