Hi All!
Please see the attached file in order to fix the bugs
Best Regards
Marcelo
Solved by Artur.Kosakowski. Go to Solution.
I have checked and I don't have similar issues with the load dialog and the bars table. Could you save the files having such displays as on the screen captures you attached and send them please?
What is your OS and language settings of Robot?
The load labeling has minor problems
Because does not increase the number after deleting one load type
e.g. Perm1, Perm2, Perm3, …, Perm7, (deleted Perm8) and continuing defining load types
e.g. Perm1, Perm2, Perm3, …, Perm7, Perm7, Perm7, Perm10
As wish list: Please include in the error message: the reason –namely, what is wrong, it will save a lot of work time
This request has been added to the wish list.
In the version 2014
The load definition window cannot be closed
I have checked on the file you sent but I can't see such issue
It displays the bar elements table as requested, but the tab name says displacements
After closing and opening the Bars table again (or for a new project) its name is displayed correctly as shown on the attached picture.
The pergola model is corrupted. What happens on your computer is very unusual and makes me think that either Robot 2014 has not been properly registered (uses files from different versions of Robot) or has not installed itself properly.
Try to register it following the steps from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Rounding-up-coordinates-API/m-p/3430533/high... (message 8).
