rioja
452 Views, 6 Replies
Minor bugs
Hi All!
Please see the attached file in order to fix the bugs
Best Regards
Marcelo
6 REPLIES 6
Artur.Kosakowski
in reply to: rioja
I have checked and I don't have similar issues with the load dialog and the bars table. Could you save the files having such displays as on the screen captures you attached and send them please?
What is your OS and language settings of Robot?
Artur Kosakowski
rioja
in reply to: Artur.Kosakowski
Dear Artur
Please see the attached files
My settings are :
You better can see in the file RobotSetting MR
Another problem has occurred
Please see the attached file named Pergola
There are errors like :
No supports
No example defined
I thank you in advance
Best regards
Marcelo Rioja
77339550
591 (3) 3363089 / 90 / 91
Enrique Finot 116
Equipetrol
Santa Cruz de la Sierra
rioja@cotas.com.bo
marcelo.rioja@me.com
Artur.Kosakowski
in reply to: rioja
You missed the files.
Artur Kosakowski
rioja
in reply to: rioja
Here the files
Artur.Kosakowski
in reply to: rioja
The load labeling has minor problems
Because does not increase the number after deleting one load type
e.g. Perm1, Perm2, Perm3, …, Perm7, (deleted Perm8) and continuing defining load types
e.g. Perm1, Perm2, Perm3, …, Perm7, Perm7, Perm7, Perm10
As wish list: Please include in the error message: the reason –namely, what is wrong, it will save a lot of work time
This request has been added to the wish list.
In the version 2014
The load definition window cannot be closed
I have checked on the file you sent but I can't see such issue
It displays the bar elements table as requested, but the tab name says displacements
After closing and opening the Bars table again (or for a new project) its name is displayed correctly as shown on the attached picture.
Artur Kosakowski
Artur.Kosakowski
in reply to: rioja
The pergola model is corrupted. What happens on your computer is very unusual and makes me think that either Robot 2014 has not been properly registered (uses files from different versions of Robot) or has not installed itself properly.
Try to register it following the steps from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Rounding-up-coordinates-API/m-p/3430533/high... (message 8).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
