Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Meshing problem - verfification not working properly
4 REPLIES 4
bartosz_borowiak
309 Views, 4 Replies
I have model exported from Revit. I spent 2 days correction geometry and finnally got no errors once I verified the model. Than I tried to run the calcs and suddenly I have plenty new location with incoherent mesh. Don't really understand why it's working this way. I locked the mesh and I got the same. Could you please advise ?
Kind regards,
Bartosz
File: http://www.filemail.com/d/jqcobuujbffafvy
4 REPLIES 4
your model stiil need correction.
There's a fine line between genius and insanity. I have erased this line - O.L.
Rafal.Gaweda
in reply to: jenyzosin
It took me 15 minutes to correct model.
Correct = get rid of incoherent meshes, but model is still not accurate, many panels are not connected to each other.
To correct model:
1. run Detailed Correct to Structural Axes ; for Whole model, Precision = 3cm
2. correct geometry of panels 931 1349 to connect them prolerly with upper slab and walls
3. correct geometry of panels 1230 1235 1240 1249 1288  for example using this macro http://forums.autodesk.com/t5/Robot-Structural-Analysis/Panel-contour-points-modification-API/m-p/38...
4. mesh panels
5. run Correction with 1cm precision or MOdel Generation with 1mm tolerance
6. run Verification
7. Correct manually  these few places with incoherent mesh
These actions will not correct many not connected to each other panels
FIle: http://we.tl/KGPdxi5ecT
Rafal Gaweda
Kind regards,
Bartosz
This is what I was telling on the other thread. Even if the verification process is ok, visually there are unjoined panels at more than 1mm size of view. this is a disadvantage if you have a very large model
MIT-BsCE
Rafal.Gaweda
in reply to: Jade_Cereno
That's why it is good to run at least on time Correction with 1cm presicion before Verification
Truly saying I do it every time, when I am playing with meshing, before running Verification
Rafal Gaweda
