I have model exported from Revit. I spent 2 days correction geometry and finnally got no errors once I verified the model. Than I tried to run the calcs and suddenly I have plenty new location with incoherent mesh. Don't really understand why it's working this way. I locked the mesh and I got the same. Could you please advise ?
Kind regards,
Bartosz
File: http://www.filemail.com/d/jqcobuujbffafvy
Solved by Rafal.Gaweda. Go to Solution.
your model stiil need correction.
It took me 15 minutes to correct model.
Correct = get rid of incoherent meshes, but model is still not accurate, many panels are not connected to each other.
To correct model:
1. run Detailed Correct to Structural Axes ; for Whole model, Precision = 3cm
2. correct geometry of panels 931 1349 to connect them prolerly with upper slab and walls
3. correct geometry of panels 1230 1235 1240 1249 1288 for example using this macro http://forums.autodesk.com/t5/Robot-Structural-Analysis/Panel-contour-points-modification-API/m-p/38...
4. mesh panels
5. run Correction with 1cm precision or MOdel Generation with 1mm tolerance
6. run Verification
7. Correct manually these few places with incoherent mesh
These actions will not correct many not connected to each other panels
FIle: http://we.tl/KGPdxi5ecT
@bartosz_borowiak wrote:I have model exported from Revit. I spent 2 days correction geometry and finnally got no errors once I verified the model. Than I tried to run the calcs and suddenly I have plenty new location with incoherent mesh. Don't really understand why it's working this way. I locked the mesh and I got the same. Could you please advise ?
Kind regards,
Bartosz
This is what I was telling on the other thread. Even if the verification process is ok, visually there are unjoined panels at more than 1mm size of view. this is a disadvantage if you have a very large model
That's why it is good to run at least on time Correction with 1cm presicion before Verification
Truly saying I do it every time, when I am playing with meshing, before running Verification
