Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Meshing problem - alignments and connections
2 REPLIES 2
OscarGaunt
567 Views, 2 Replies
Hi I am tryin to model a steel tank using meshing.
I am having a problem with making meshes that join at angles to connect so they act together. No matter what I do I can not make the platee that are at angles join correctly, even when i draw the new mesh at each individual node. Please see images below of example where this has happened, along with an atached file.
Thank you for your time.
Oscar Gaunt
2 REPLIES 2
Rafal.Gaweda
in reply to: OscarGaunt
Are panels well connected on common edges? From first screen shot I can see they are apart.
Send us model to check.
Rafal Gaweda
OscarGaunt
in reply to: Rafal.Gaweda
Sorry problem solved now!
