for some reasons I modeled a plant into two different parts and I studied the two parts separately; now I need to join them in order to perform a different analysis on the whole production plant. Is it possible to add one model to the other, or insert them in a new project / file?
And how?
Many thanks
Giorgio Lucca
Solved by Artur.Kosakowski. Go to Solution.
Geometry > Structure > Insert from File > *.rtd
Just Remember to have a look at the self-weight load case.
If it´s generated automatically by Robot AND they have the same name on both models , You´ll get the generated self-weight listed twice on the Load table of the merged model.
Just delete one of these lines to have the correct generated self weight
Rafael Medeiros
