A quick question on panels. i have set up a simple example to illustrate the issue i am having. (see attached)
I would like to merge 2 panels so that when i use reduced results i get a single axial force and moment... is there a way to do this! i have used ETABS before and it had an option for defining piers!!
Does robot have somthing similar?
Please let me know ASAP cause it is very important for the project i am working on now.
Kyp
Solved by Rafal.Gaweda. Go to Solution.
Hi Rafal
Is it possible to use the propsed solution below to influence span directions of particular finite elements in a larger panel?
I have a suspended slab mostly spanning in one direction (precast), but a couple of areas are to be cast in-situ (2 way spanning) or have the panels spanning at right angles to the main span direction. Short of dividing the panel into smaller panels at beam locations, would a workaround be to select the finite elements in areas where I have described above, and assign different properties to them?
Set correct local X of panel instead
for results presentation set correct direction (any suitable for you hidden under button marked below in red ; similar way for FE results table)
for reinforcement (any suitable for you from screen shot below ; not only marked in red)
stroxy wrote:
- Is it possible to workaround without subdividing the panel?
No
- If not, is there a simple way of subdividing a panel at say grid or beam locations?
Are you refering to option Edit \ Cut by Plane implemented in 2015?
I still not clear to me how do you actually merge two panels as one? I've tried the procedure on the screenshot but it doesnt work for me. I would like to merge two slabs as one?Can I have a further explanation regarding this/ Any ideas will be apprecited.
