Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
738 Views, 1 Reply
Membrane forces
I have run an modal analasys and a  seismic analysis witch generates forces. Ive had a lok kat the mambrane forces in the plate but there are only tention forces.why aren't there any comp. forces?  does the seismic force witch is gen. for the x- dir. the max respons of the quanteties in +x and -x dir. tis is not on the basis of latheral force method where the signs of the forces ar ceept.
best regards
is it the -Nyy/Nyy as the compretion/tenstion??? Need explantion
https://www.filemail.com/dl.aspx?id=EDGSUKNELFXHAAO
1 REPLY 1
Artur.Kosakowski
You should look at results for particular mode rather than CQC combination unless you create the signed quadratic combination.
Artur Kosakowski
