Discussion Groups
Robot Structural Analysis
Distinguished Contributor
bjur
Masonry wall design
774 Views, 3 Replies
03-29-2012 08:15 PM
Can robot design masonry shearwalls / bearing walls? There are many masonry structures here in the US and I assume a program this powerful could design structures like this. Do I just create a wall element with similar stiffness properties as a masonry wall? Can robot provide wall stress / loading summeries or do I need to sum forces in the plates by hand?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Masonry wall design
03-30-2012 12:03 AM in reply to: bjur
There is no devoted design module for masonry walls available but you can define a panel with corresponding material properties. You can access results in many different ways such as maps or cuts (graphical display) as well as tables (e.g reduced results for panels).
Artur Kosakowski
Active Member
10-17-2012 04:10 AM in reply to: Artur.Kosakowski
Well, i'm just wondering, is it any option in RSA  to create a structure (in this case,  masonry wall with opening, assume, that reinforced concrete lintel holds all the load), which has no tensile strengh? Thanks very much for your reply.
Product Support
Artur.Kosakowski
10-17-2012 04:24 AM in reply to: MykolasM
No, there is not unless you delete the part over the linter (where you have tension) and 'replace' the weight of this part with load applied directly to the lintel.
Artur Kosakowski
