Hi!
When trying to enter in RC wall I can only click on Simple loads, Manual combinations is grey and cant click on it. I am using French Eurocode. Is there a way to choose my manual combinations?
If I choose simple loads in RC wall how to generate combinations and coefficients identicaly as my manual combinations??
My model you can find on link: http://www.4shared.com/file/TzniKQsY/glavni_model_jos_jednom.html?
Please help
Solved by Artur.Kosakowski. Go to Solution.
This functionality is available starting from SP1 for Robot 2013. Please navigate to Robot Updates & Service Packs and install SP4 for Robot 2013.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Only ULS. For the alternative approach check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/walls-openings-reinforcement/td-p/4308048
