Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Manual combinations for RC walls
3 REPLIES 3
aprule16
411 Views, 3 Replies
Hi!
When trying to enter in RC wall I can only click on Simple loads, Manual combinations is grey and cant click on it. I am using French Eurocode. Is there a way to choose my manual combinations?
If I choose simple loads in RC wall how to generate combinations and coefficients identicaly as my manual combinations??
My model you can find on link: http://www.4shared.com/file/TzniKQsY/glavni_model_jos_jednom.html?
Please help
3 REPLIES 3
Artur.Kosakowski
in reply to: aprule16
This functionality is available starting from SP1 for Robot 2013. Please navigate to Robot Updates & Service Packs and install SP4 for Robot 2013.
Artur Kosakowski
aprule16
in reply to: Artur.Kosakowski
Can I use SLS combinations or just only ULS?????
Artur.Kosakowski
Only ULS. For the alternative approach check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/walls-openings-reinforcement/td-p/4308048
Artur Kosakowski
