Hi Rafal
My company is using ARSA 2014 now> I have two questions:
1- How Manual combination is made? please declare in a screen shot.
2- How required reinforcement for column is done.
I couldn't manage them.
In advance I appreciate your help.
Hi Rafal
I didn't get these problems in previous versions. When I defined manual combination, it appeared in column design module. but now it doesn't appear in column design module. I read posts and there was suggestions about using SP3, but I don't knoe what is this.
Another question. If the manual combination doesn't appear in column design module ( provided reinforcement), does it mean that there isn't combinations between the load cases? If so, how can I solve this proble.
Best regards.
Definition of manual combinations:
Robot 2014 SP4
Importing a column from a model you can decide if you want to import simple load cases (then combinations are automatically generated inside the RC Column Design module) or manual combinations defined in the model.
