HoshangMustafa
223 Views, 2 Replies
Manual combination
Hi Rafal
My company is using ARSA 2014 now> I have two questions:
1- How Manual combination is made? please declare in a screen shot.
2- How required reinforcement for column is done.
I couldn't manage them.
In advance I appreciate your help.
2 REPLIES 2
Hi Rafal
I didn't get these problems in previous versions. When I defined manual combination, it appeared in column design module. but now it doesn't appear in column design module. I read posts and there was suggestions about using SP3, but I don't knoe what is this.
Another question. If the manual combination doesn't appear in column design module ( provided reinforcement), does it mean that there isn't combinations between the load cases? If so, how can I solve this proble.
Best regards.
Definition of manual combinations:
http://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/CloudHel...
Robot 2014 SP4
http://knowledge.autodesk.com/support/robot-structural-analysis-products/downloads/caas/downloads/co...
Importing a column from a model you can decide if you want to import simple load cases (then combinations are automatically generated inside the RC Column Design module) or manual combinations defined in the model.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
