Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Macro doesn't work with RSA 2013
5 REPLIES 5
TraitCarré
315 Views, 5 Replies
this macro gives the Error msg (it can't find the Robot Application) when model opened with ARSA 2013 (26.0.3.4375 (x64)), but works with ARSA 2011 (24.0.0.3481) :
Set RobApp = New RobotApplication
If Not RobApp.Visible Then
    Set RobApp = Nothing
    MsgBox "Open Robot and load Model", vbOKOnly, "ERROR"
    Exit Sub
Any ideas?
rgds
Benoît
5 REPLIES 5
Rafal.Gaweda
in reply to: TraitCarré
TraitCarré
in reply to: Rafal.Gaweda
I've tried all, it doesn't work 😞
Macro doesn't work since I upgrade from RSA 2013 SP0 to SP3.
Please see attached document : it seems that I have the wrong VBA references (ver 11.0 only) and the file path seems to be wrong since I run RSA 2013 from "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis 2013".
thanks
Benoît
Rafal.Gaweda
Have you tried what is written in
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-not-running-after-RSA-upgrade/m-p/343205...      message 4 ?
Rafal Gaweda
TraitCarré
doesn't work 😞
Rafal.Gaweda
