Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Loadtakedown model and wind model (?)
5 REPLIES 5
AlexDT
329 Views, 5 Replies
I've exported my RST model to RSA. In RST I could choose to make a wall just bear gravitational forces of just shearforces from wind. These parameters are not transferred to RSA.
How can I define in RSA that some walls should only bear vertical forces and other only horizontal forces?
Is it possible or do these 2 been seperated?
(Im problably not using the right english terms, please correct me if needed. thanks)
5 REPLIES 5
Artur.Kosakowski
in reply to: AlexDT
As Robot is FEM based software the load distribution depends on stiffness of objects (bars, panels) and you cannot use sort of 'manual' calculations arbitrary  assuming where your load should go. You can try to 'direct' lateral and vertical load transfer using releases.
Artur Kosakowski
AlexDT
in reply to: Artur.Kosakowski
Thanks, might be a important point in my conclusion!
Artur.Kosakowski
in reply to: AlexDT
Artur Kosakowski
Artur.Kosakowski
in reply to: AlexDT
Alex,
You may want to look at CBS where for the simplified calculation methods such definition is possible.
Artur Kosakowski
AlexDT
Good to know. I might check that out later as I am focussing on RSA. Thanks!
