Good Morning / Evening ;
Is there a way to force RSA to load in a given version ( lets say 2013 ) by using API rather than another one (2011 ) when they are installed in the same machine ?
Thank you
Solved by Rafal.Gaweda. Go to Solution.
Dim x As Variant Dim Path As String Dim V As String Path = "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE" V = "/RegServer" x = Shell(Path + " " + V, vbNormalFocus)
Example (registering v2013) attached.
Even if a project under RSA 2013 is loaded , the "command" set app = new Robotapplication doesn't connect my VBA programm with RSA.
Instead of that it looks to load RSA 2011 ?!
Ive already registred the 2013 as per component registration attached.
Thank you for help
Search forum
you need to unregister 2011 while being in command propmpt opened in Admin mode, then unregister 2013 from it then from this command prompt register 2013
or try in code unregister 2013, unregister 2011 (/UnRegServer) then register 2013
