Discussion Groups
Robot Structural Analysis
Active Contributor
STP_MS
Load transfer slab to beam and beam offset
1223 Views, 5 Replies
03-27-2013 06:42 AM
I am analysing concrete slab supported by two metal beams.
I have created test model with 4 storeys:
Story 4 - concrete slab + metal beams without offset
Story 3 - concrete slab + metal beams with offset
Story 2 - cladding + metal beams without offset
Story 1 - cladding + metal beams with offset
Problems I have:
1. Storyes 3 and 4 - slabs do not transfer load.
2. Story 1 - How to avoid moments over supports.
Can you help me with this?
Here is the link to the model: http://www.4shared.com/file/sXm7Z-i5/TEST_MOD_0_0.html
Please use plain text.
Product Support
Rafal.Gaweda
Re: Load transfer slab to beam and beam offset
03-27-2013 07:10 AM in reply to: STP_MS
Wrong load type - must be any (FE)... load
Rafal Gaweda
Active Contributor
STP_MS
03-27-2013 07:33 AM in reply to: Rafal.Gaweda
Thanks for answering question No.1.
For question No.2:
I am trying to get results like on Story 2 - beam independant from the slab.
To be precise, I want to transfer the load from the slab to the beam without two of them "working together".
How can I model this?
3. Additional question: Is there a way to show beam with offset without influence to the calculations? I need it for presentation purposes
Product Support
Rafal.Gaweda
03-27-2013 08:28 AM in reply to: STP_MS
Either make two models or use Word or PowerPoint to "prepare correct" presentation making screen shots from Robot.
Rafal Gaweda
Product Support
Rafal.Gaweda
03-27-2013 08:40 AM in reply to: STP_MS
If I understood you correclty:
- there is no slab on Story 2 (only cladding) so the beams works independent
Whatever
- you may use panel with calculation model like that (such or similar settings (Stiffening in XY)):
- or use Linear releases on panels edges
or like in message 5:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Meshed-slab-supported-by-beams/m-p/3167096/h...
Rafal Gaweda
