Discussion Groups
Robot Structural Analysis
Active Contributor
Accepted Solution
Load to mass problem
177 Views, 2 Replies
02-20-2013 01:50 AM
When I try to convert load to mass, the program converts the loads that are applied on bars only, not those on shell elements.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Load to mass problem
02-20-2013 01:56 AM in reply to: sedefass
Create a new load case where you have only loads applied to shells. Run static analysis of this case and check that the load is applied correctly. Then in the modal analysis mark disregard density and convert only the new load case to mass. Run calculations and check the total mass in the results of modal analysis case. If it is 0 then send us this model.
Artur Kosakowski
Active Contributor
02-21-2013 05:23 AM in reply to: Artur.Kosakowski
Thank you Artur!
