Is it possible to sort loads into their load cases rather than in chronological order.
In the attached picture the load cases in the rows are 1, 6, 7 3, 2 etc. It would be useful if they were grouped in load cases.
James
Solved by Artur.Kosakowski. Go to Solution.
Double click on the header of the 1st column.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Is there any way of permanently re-arranging tables into numerical/alphabetical order to save having to sort by double-clicking each time?
The only way I can think of is to copy into excel, sort by column, then paste back into Robot.
Hi @Benmason
I haven't checked if this works but you may try to open the model in the repair mode:
ROBOT-how to open file in repair mode
Hi @Benmason
So it seems that sorting is the only solution. In case you want to look at it from a different angle - I find this behavior extremely helpful when you want to edit values of loads when you copy part of the existing load to a new (empty lines). Then you will find them at the bottom so changing their assigned load case to another and editing values is easy which wouldn't be possible if these records appeared in 'into numerical/alphabetical order'.
