Discussion Groups
Robot Structural Analysis
Участник
Accepted Solution
Load distribution option for cladding (v.2013)
465 Views, 4 Replies
10-16-2012 04:53 AM
I’m really confused: how to select the bars that don’t participate in load distribution or at least ignore truss bars, if the option in menu is not active as the selection in dialog box?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Load distribution option for cladding (v.2013)
10-16-2012 04:59 AM in reply to: Участник
Artur Kosakowski
Участник
10-16-2012 06:27 AM in reply to: Участник
Thank you for showing that selection should be active.
I was asking because I had this in FRAME 3D:
and this in SHELL:
Distribution options available after changing Structure Type to BUILDING and back.
Valued Contributor
CKDDIZ
04-08-2013 05:55 AM in reply to: Участник
1 - if using claddings, the bars that should not participate have to be selected and ignored? ex. bracings and main beams in the pic. below?
2 - where is the difference between using claddings and panel, pic 2 ?
Product Support
Artur.Kosakowski
04-08-2013 06:23 AM in reply to: CKDDIZ
Correct.
 A cladding is just a 'dummy' object that has got no influence on the deformation of a model. A panel is a set of 'real' surface elements which have properties of the thickness you assigned to it and it has got the influence on deformation of a model.
Artur Kosakowski
