Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Load definition and combinations
1 REPLY 1
pringle_de_tom
307 Views, 1 Reply
I've attached my load definitions for a flat slab design. I'm wondering if I've done it correctly so that the programme will generate combinations with leading and accompanying variable actions properly. Should I have all variable/live load within one load definition or is it correct the way I've done it all separated into the individual components?
Cheers,
Tom
1 REPLY 1
You should define live loads as separate load cases.
Artur Kosakowski
