I've attached my load definitions for a flat slab design. I'm wondering if I've done it correctly so that the programme will generate combinations with leading and accompanying variable actions properly. Should I have all variable/live load within one load definition or is it correct the way I've done it all separated into the individual components?
Cheers,
Tom
Solved by Artur.Kosakowski. Go to Solution.
You should define live loads as separate load cases.
