Somewhere along the line my load combinations have been deleted. Rather than re-entering them all, is it possible to manually copy them from an older model's load combinations table to my current load combination table?
Solved by Rafal.Gaweda. Go to Solution.
It is not an option. The Paste function is greyed out. It is actually just the definitions that have changed. Even if I try and paste/edit each definition separately it does't work... it doesn't allow editing of the table.
