Hi all.
I want load wind to centren of geometry of slap.
please toturial me seach centren of geometry of slap
I is attachment
please convert *.doc* to *.rar*.
Thanks support
Solved by Rafal.Gaweda. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
There are two options:
1). Use forces in points (see the attached picture)
2). Use panels instead of claddings - check this topic http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Wooden-frames-in-Robot-structural-analysis-a... and focus on the message 4
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Thank Artur.Kosakowski
I is Know.
Please toturial guide me
1)how to find Centre of mass point coordinates ( XYZ)
2) how to find centre of rigidity point coordinates (XYZ)
Thank you.
NOTE: panels must be meshed
To create stories: Geometry \ Stories \ Stories
Stories resuls table : Results \ Stories
Hi. I created model ETABS and ROBOT
But centren of mass and centre of rigidity different???????? Pleaes help me. Thank
ETAB
ROBOT
i ATTACHMENT FILE
Convert *.doc* to *.rar*
Thank
1. Ask ETABS
2. Do not compare slab resuls and story results.
Thansk
but I can not find centre of mass.
I just saw center of gravity and center right. But i don't see center of mass.
Please help me.
thanks tony.
Your comments help me to define such a right?
1. center of geometry = F - Coordinates of the center of gravity of story slab
2. center of mass = G - Coordinates of the center of gravity of story
3. center of rigidity = R - Coordinates of the center of rigidity of the section at the height of the story's center of gravity, considering the columns,walls and core walls.
Please. THansk
Your post
"thanks tony.
Please. THansk"
What do you mean, "define such a right"?
