Typically for partitions above beams but not on the whole lengh.
Avoid to specify the coordinates on the lenght or to split the bars.
But needs a cladding, however useful in my opinion.
See Ya
example :
when you have to apply a linear load on bar at 1 meter from support and 1.40m before the end of the bar, it is not easy to define this -> you have to know the lengh, define the load etc .... or to divide the bar into 3 parts and apply a uniform load to it.
Instead of doing that you can set 2 points on the edge of a cladding supported by the bar to define the load as you want, I find this way much easier.
That's all 🙂
How do you personnaly do define this kind of loads ?
The tool to define loads on part of a bar is the trapezoidal load, it requires to know the value of the position, doesn't work only with 2 points or am I missing something?
One precision : I am used to import the .dxf from the architect in order to see where are the partition and then the loads, maybe that's why I find this a good solution
THis way, without generating additional nodes or spliting bars
That's exactly what I want to avoid because I don't to measure each X1 and X2 ... that's why I put nodes
But actually could it be possible to add a the definition x3 :
Uasually I know that the load is at xm from the support so to avoid an operation which be repeated a lot of time, would it be possible to have x3 = L - x2 ?
Maybe I am the only one to find the current definition not so easy to use ... 🙂
