Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Little Trick : Linear partial load on bars
9 REPLIES 9
Message 1 of 10
t.sautierr
1105 Views, 9 Replies
Typically for partitions above beams but not on the whole lengh.
Avoid to specify the coordinates on the lenght or to split the bars.
But needs a cladding, however useful in my opinion.
See Ya
9 REPLIES 9
Message 2 of 10
Rafal.Gaweda
in reply to: t.sautierr
No idea what you mean.
Rafal Gaweda
Message 3 of 10
t.sautierr
in reply to: Rafal.Gaweda
example :
when you have to apply a linear load on bar at 1 meter from support and 1.40m before the end of the bar, it is not easy to define this -> you have to know the lengh, define the load etc .... or to divide the bar into 3 parts and apply a uniform load to it.
Instead of doing that you can set 2 points on  the edge of a cladding supported by the bar to define the load as you want, I find this way much easier.
That's all 🙂
Message 4 of 10
Rafal.Gaweda
Strange = interesting idea but it works
I would personally try to avoid claddings in such situation but...
Rafal Gaweda
Message 5 of 10
t.sautierr
How do you personnaly do define this kind of loads ?
The tool to define loads on part of a bar is the trapezoidal load, it requires to know the value of the position, doesn't work only with 2 points or am I missing something?
One precision : I am used to import the .dxf from the architect in order to see where are the partition and then the loads, maybe that's why I find this a good solution
Message 6 of 10
Rafal.Gaweda
THis way, without generating additional nodes or spliting bars
Rafal Gaweda
Message 7 of 10
t.sautierr
That's exactly what I want to avoid because I don't to measure each X1 and X2 ... that's why I put nodes
Message 8 of 10
Rafal.Gaweda
As I told you - your choice, your trick 🙂
Rafal Gaweda
Message 9 of 10
t.sautierr
Oki doki 😉
Message 10 of 10
t.sautierr
But actually could it be possible to add a the definition x3 :
Uasually I know that the load is at xm from the support so to avoid an operation which be repeated a lot of time, would it be possible to have x3 = L - x2 ?
Maybe I am the only one to find the current definition not so easy to use ... 🙂
