Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Linear link between slabs/floor
8 REPLIES 8
Message 1 of 9
pevelor
2239 Views, 8 Replies
Hi
I need a linear connection between two slabs not laying in the same plane.
Does Robot have such a tool similar to rigid link but for along a full edge?
Regards
Peder
8 REPLIES 8
Message 2 of 9
Rafal.Gaweda
in reply to: pevelor
Yes use rigid links or vertical panel with high stiffness.
or
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Modelling-RC-beam-with-slabs-connecting-at-d...
Rafal Gaweda
Message 3 of 9
Refaat
in reply to: Rafal.Gaweda
Dear Rafal / Artur
Greetings
Could I do to model a beam at the center line elevation of the actual beam and then use (RL) to connect the beam with upper and lower slab ( First capture ) ?
If so, then:
1. Is it correct to use (RL) at the beam ends (Column locations) as indicated in the first capture?
2. If I use a panel instead of beam (Second capture), is there any way to compare the analysis results between (Panel vs. Beam) for instance (Bending moment)?
rtd. File is attached
Thanks in advance
Refaat
Message 4 of 9
Refaat
in reply to: Refaat
Dear Rafal / Artur
Any response will be  appreciated
Refaat
Message 5 of 9
Artur.Kosakowski
in reply to: Refaat
I think it is as you did the same for  tho other mode.
Only indirectly making a series of vertical cuts and checking the reduced moments in them.
Artur Kosakowski
Message 6 of 9
Refaat
in reply to: Artur.Kosakowski
Dear Artur
Thank you a lot for the support given.
Refaat
Message 7 of 9
Artur.Kosakowski
in reply to: Refaat
Dear Refaat,
I think we all should thank you very much for your contribution to this forum.
Artur Kosakowski
Message 8 of 9
Refaat
Dear Artur
The thanks go to all members of  RSA technical support team (Especially You & Mr. Rafal) .
I am very happy with these contributions in this wonderful forum.
Yours sincerely
Refaat
Message 9 of 9
rreinaldo
in reply to: Refaat
@Refaat Did you found any difference using the two approaches? I mean using panel or beam.
Thx.
