Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Library structure error for French language when ACIER material is not available
7 REPLIES 7
Message 1 of 8
716 Views, 7 Replies
Hi   I downloaded trial version of ARSAP 2013
je telecharger la version 2013 et je voulais faire quelque exemple, mais quand je choisie le icon de structure type, RSAP fait un message d'erreur de que je clic deux fois sur la structure que je veux choisir
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
The message suggests that you tried to load one of the library structures. Could you check what materials (French or English/Eurocode) as well as section databases you have got set in Job Preferences? Mind that for French language ACIER material has to be available. In case it is missing add create it e.g. using Steel as the reference.
Artur Kosakowski
Message 3 of 8
in reply to: Artur.Kosakowski
hi
when i do this a have probleme, i think it is'nt good instaled!
Message 4 of 8
Artur.Kosakowski
truss.PNGIn case some of bars (posts and diagonals) do not have assigned sections after you press OK (ignore any displayed warnings) select them and assign sections using the Sections dialog instead.
Artur Kosakowski
Message 5 of 8
hi
i use canada franch version, it is trial version, in picture the are what i have when i try to use tipical structure
Message 6 of 8
jad.dellel
Bonjour,
Comme indique' dans le message 5, il faut verifier la compatibilite' de la base des materiaux avec les preferences regionales:
veuillez verifier que vous avez bien les parametres affiches dans les captures ci-dessous:
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 7 of 8
in reply to: jad.dellel
it is ok
mais moi pour le parametre regionaux c'est canada français. mais je vois que ça fonctionne pas. pour acceder aux structures types et  la norme canadienne CISC je dois utiliser l'anglais.
merci mais je pense que vous devez corriger ça pour vos client au Quebec
Message 8 of 8
jad.dellel
Utiliser les preferences indiquees pour generer la structure, ensuite modifier les sections de votre treillis.
Jad DELLEL
