I created Panel releases in hollow core slabs in my 21 storey model, now I wanted to simplify the model and decrease the number of FEM elements so I changed the slab type to deck slab with diaphram. Now I want to go and delete all the panel linear releases and I could not find any tables in the UI to do that, and it is a very time consuming to go and release panel by panel in this big model. I also realised that there are some features like Advanced bar properties are also not tabulated in the program and ofcoarse the input file cannot be text edited which is a major drag in my opinion in the RSA.
How can I easily access these features without having to go and delete/edit them piece by piece?
Solved by Artur.Kosakowski. Go to Solution.
