Joint steel beam and rc plate
1 REPLY 1
pevelor
368 Views, 1 Reply
Hi
I am trying to analyze a slab supported by steel beams. Its kinda a spesial situation since we want the steel beams to be bolted up into the slab to act as the tension reinforcement.
What do I have to do to simulate this correctly?
I want to know both the section height for the beam and how many bolts I will need.
Tags (2)
1 REPLY 1
Artur.Kosakowski
in reply to: pevelor
You may try the following approach:
1. Define beams under the slab and connect them with the slab by short bar elements
2. Size beams using the steel design module
3. Adjust position of beams depending on  the final section sizes
4. Check shear forces in short bars and use them for bolt design
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
