Discussion Groups
Robot Structural Analysis
GabrieleNovembri1027
Italy NTC 2008 add on Mpl,rd,y problem
391 Views, 2 Replies
01-20-2012 01:59 AM
Hi All,
I'm trying to use Italy NTC 2008 for steel and I found some things that I do not understand. In the beams verification the comparison between the plastic moment and the acting moment is calculated as provided in (4.2.13) as the ratio between the acting moment and plastic moment of the section divided by the coefficient 1.05.
In the note enclosed for the beam  No 280 (HE300B profile) is reported a plastic moment of 513.92 kN*m which seems not divided by a factor of 1.05 provided by the NTC in 2008 (4.2.13).
The plastic  moment should be 489.4 kN *m. As the acting moment is equal to -92.66 kN*m the calculated ratio should be 0.1893 instead of 0.1803, or in other words 0:19 and not  0:18.
I don’t know If I am right
Please use plain text.
Member
Massimo.Speziani
Re: Italy NTC 2008 add on Mpl,rd,y problem
01-23-2012 05:20 AM in reply to: GabrieleNovembri1027
Hi Gabriele,
That value could be due to the fact that the seismic combinations are ACC or SIS-ECC. In attachment an example of calculation of Mpl,rd with SIS-ECC and SIS-ULS. The value in case of SIS-ULS is 489.4 kN *m. No gamma reduction is applied for SIS-ECC
Best Regards
01-24-2012 06:52 AM in reply to: Massimo.Speziani
Hi Massimo,
Thanks fotr the infotmation.
Gabriele
