Discussion Groups
Robot Structural Analysis
Active Contributor
Isolated nodes are multiplying
130 Views, 5 Replies
02-11-2013 12:06 AM
Hey!
I have a problem with  the numbers of isolated nodes getting larger after i have deleted them and run the analasys again.. As i have undrestod the problem lies in the liniear releeses and that they are multipli difined on conected edges.. is this the case?
how may I sort the problem?? the fil is given in the link.
 https://www.filemail.com/dl.aspx?id=BMMZNVQKARCTETS
Please use plain text.
Product Support
Artur.Kosakowski
Re: Isolated nodes are multiplying
02-11-2013 12:20 AM in reply to: oyvinkle
You should define the linear release for only one panel (along the edge that is common for two panels).
Artur Kosakowski
Active Contributor
02-11-2013 12:25 AM in reply to: Artur.Kosakowski
Is it the same as for three edges?
I also get an error that ses "it is necessarry to divide tapered bar to valcilation elements for non -linear analysis"
How may i find where the elemnts are and how to remove them?
Product Support
Artur.Kosakowski
02-11-2013 12:29 AM in reply to: oyvinkle
Then define them for two panels only.
My understanding it that the actual warning is in fact that it is recommended divide (not remove) the bars of variable height for better precision of the results.
Just select these bars using their section names as the selection filter.
Artur Kosakowski
Active Contributor
02-11-2013 01:05 AM in reply to: Artur.Kosakowski
I im not shure if I know what you mean by that, The bars are dividet into 20 segments i beleeve witch sould be satesfactory for convergens..
Product Support
Artur.Kosakowski
02-11-2013 01:41 AM in reply to: oyvinkle
In the model you sent I can't see any such warning so my answer was the general one. As far as I can see you haven't installed SP3 for Robot 2013. I recommend you do so. The link is inserted below:
Robot Updates
Artur Kosakowski
