See the attached.
Wrong deflections are reported.
See Bar #8 as an example.
Is this the answer you are looking for?
The problem is that cantiliver deflection comparison is wrong!
Why is uz used rather than UZ?
I have attached output from another model. Look at Bar No 8 deflections please.
I think this is correct for the parameters you defined. You need to 'tell' the program that you this is a cantilver
I'd rather decide myself if this is a cantilever or a suspended beam. Anyway currently you have to decide yourself
Suggest that the "cantilever option" be a Bar Property rather than burying the option outside of analysis / results and down several levels.
