Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Is there a way to generate automatic Axis defintions ?
8 REPLIES 8
Message 1 of 9
nany717
488 Views, 8 Replies
While modeling a structure frame, I started with no axis definition and went on by using copy/move commands. The structure is pretty standard one, so I didn't bothered to create Axis definition prior to modeling.
Now I have a (big) frame structure with me and I want to see the axis information, so that I can have a screenshot of the model with all the axis and grid info.
Is there any way to automatically generate Axis and grid based on columns and floors ??
8 REPLIES 8
Message 2 of 9
Rafal.Gaweda
in reply to: nany717
Open Structural Axes definition window, activate tab(s) and click on model in the place you want to have a grid line, level.
Rafal Gaweda
Message 3 of 9
nany717
in reply to: Rafal.Gaweda
Thats like creating axis manually, right. I have to click each time I want an axis.
I am asking, if there is any way to avoid this.
Message 4 of 9
Rafal.Gaweda
No.
Rafal Gaweda
Message 5 of 9
Artur.Kosakowski
How such option should work? Please mind that it should be a general one which means columns and walls being 'randomly' located in the model as you are not 'restricted' by the program interface to create only lines of them.
Artur Kosakowski
Message 6 of 9
nany717
Aah...
Thank you.
Message 7 of 9
Artur.Kosakowski
If you have equal spacing among the lines of columns you can indicate the position of the first one and set the number and distance to generate all axes 'automatically'.
Artur Kosakowski
Message 8 of 9
rioja
in reply to: Artur.Kosakowski
There is a way ou can create your axis quickly
Create Nodes in  excel xyz, where you want to have an axis (create a 3D - diagonal for example)
Paste all nodes in the Node Table
Be sure all the nodes are visible
Open Structural Axis manager
Click over each node you need for de X tab, for the Y-tab and for the Z-tab
Apply
Select all nodes and delete if you want or you dont need any more
Done!
Message 9 of 9
nany717
in reply to: rioja
Yes, thats the manual way to do...But if the structure is huge with sevral floors and inner partitions, this way of doing will take time.
@Rioja : I already have a structure built in the model, so I dont think I have to create separate nodes from the excel...As you said I generated axis by clicking each node.
