There is a separate node which is invisible, so I can't delete it.
It seems that I get wrong results in "Dimensionnement bois", as the value of the deflection is 1000 times the value given on the results table, and the graphical deformation doesn't show so much flexibility.
thanks for your help
Benoît
Turn off Stories and check or remove it from table
File please.
-> What do you mean by "stories" : level? There're no level (file attached). the node doesn't appear in table.
Look what happen when I run several calculation of timber design in the same time : the table at the top was generated when several calculations were running, as the second at the bottom was running alone! The results for deformation are so different!
I thougt it was possible to run several calculation, as it is written here :
"09-18-2012 02:11 AM
Moreover as concerns operation 4/ (steel/aluminium/timber design) user
can start several such calculations simultaneously with for instance
different list of members or groups and each of them can be performed by
different processor.
Rafal Gaweda"
Claddings 417 449 are not accurate
Move indicated corners to locate them exactly on bar 371 or change Model Generation tolerance to 2mm
Thx, it will be investigated.
Workaround : Run one design calculations in time
Ok, thanksfor the hiden node, I did not think it could be a calculation node
I don't know the parameter Model Generation tolerance. Is it the little hamer for structure correction?
If you look above you will see it on my screen shot
