Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Installing RSAP Design Spreadsheets silently...
17 REPLIES 17
Message 1 of 18
ukdxb012
1845 Views, 17 Replies
Hi There,
Has anyone tried to install RSAP Design Spreadsheets / Spreadsheet Calculator silently via SMS or as a package??? I need some advice on how to do this if possible.
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
17 REPLIES 17
Message 2 of 18
Rafal.Gaweda
in reply to: ukdxb012
It is, by installshield script.
I will try to prepare procedure and post it here.
Rafal Gaweda
Message 3 of 18
ukdxb012
in reply to: Rafal.Gaweda
That would be great help! Many thanks and i will look out for your reply 🙂
Duncan Brannan
Twitter | LinkedIn
Message 4 of 18
Rafal.Gaweda
I have updated old document. Screen Shots (paths \ filenames) are outdated but the rest should work.
PS
Of course you can use batch file \ command to run installation:
SpreadsheetCalculator2013_Content.exe -s -f2c:\SC.log    (log file SC.log will be created on each computer on c: root folder)
Rafal Gaweda
Message 5 of 18
ukdxb012
Many thanks for providing this, however, i'm stuggling to get this to work i think... Are you able to offer any further advice?
I have managed to create a setup.iss file located in the Windows folder by using the -r (switch) which i have copied into a folder on our shared network drive which uses dfs for replication along with the spreadsheetcalculator2013_content.exe
Then I created an ipf file with the following information...
item: Remark
  Text=---Robot Structural Analysis Pro Design Spreadsheets for Autodesk Robot Structural Analysis 2013---
end
item: Execute Program
  Pathname=Extensions\spreadsheetcalculator2013_content.exe
  Command Line=/s
  Default Directory=\\dfs\KITS\ADesk\Robot Structural Analysis Pro 2013 X64
  Flags=00000010
end
Extensions is the folder with the exe and the iss in.
I then compiled the ipf too an exe file and ran the file which seems to do something, however if i check the Control Panel, it doesnt state that the Design Spreadsheets are installed...
I've tried the shortcut as suggested but it didnt do as expected... am i pathing to the wrong thing?
I did have success with the Log file as suggested but it gave me very little information...
[InstallShield Silent]
Version=v7.00
File=Log File
[ResponseResult]
ResultCode=-5
Duncan Brannan
Twitter | LinkedIn
Message 6 of 18
Rafal.Gaweda
1. Check if SC is working as it should - load any sheet from library.
2. Run installation (-r) manually \ by batch
3. Let me know the results. If failed I need to check this installation on my side.
Rafal Gaweda
Message 7 of 18
ukdxb012
When i load the Spreadsheet Calculator i just get a blank sheet with no options to select a template...
Installing manually, the Design Spreadsheet works fine and i get a pop up asking which template i want, i just need a way to install this working method silently via SMS.
Would you mind checking from your side and confirming the steps etc.
Duncan
Duncan Brannan
Twitter | LinkedIn
Message 8 of 18
Rafal.Gaweda
Thanks for reply , I will check.
Rafal Gaweda
Message 9 of 18
ukdxb012
Hi Rafal,
I was wondering if there is an update to this or can i presume that it is not possible to install this silently? i did receive an email from Autodesk asking if this had been resolved of which i said no, but that was the last i heard anything...
Thanks in advance
Duncan Brannan
Twitter | LinkedIn
Message 10 of 18
Rafal.Gaweda
I am working on it. No final conlusion yet.
Sorry for delay.
Rafal Gaweda
Message 11 of 18
Rafal.Gaweda
It seems my fault, I have forgotten that instalation should be "unpacked installation".
use this package http://www.4shared.com/zip/TFRANA_3/SC2013_Content.html
unpack all files to one folder then use setup.exe to record then run installation
Rafal Gaweda
Message 12 of 18
ukdxb012
Rafal,
Do you know if the same process applies to the 2014 version of the Design Spreadsheets to install them silently?
Duncan
Duncan Brannan
Twitter | LinkedIn
Message 13 of 18
Rafal.Gaweda
Should work.
Rafal Gaweda
Message 14 of 18
ukdxb012
I'm afraid not, it's asking for the next disk...
"Please insert disk 2 that contains the file data2.cab" - I cannot find this anywhere unfortunately!
P.S - Is there a more simpler may to do this?
Duncan
Duncan Brannan
Twitter | LinkedIn
Message 15 of 18
Rafal.Gaweda
I will send you package - most likely tomorrow.
Rafal Gaweda
Message 16 of 18
ukdxb012
Many Thanks!
Duncan Brannan
Twitter | LinkedIn
Message 17 of 18
Rafal.Gaweda
Package : http://we.tl/Wgh4YkKaH2
Rafal Gaweda
Message 18 of 18
ukdxb012
Rafal,
Thanks for the download, this now works as expected, many thanks 🙂
Duncan
Duncan Brannan
Twitter | LinkedIn
