Im working on a 34 m rectangular truss.After running calculations..the results showed "instability" in some members.
Some had yellow color, others had red and yellow.
What do the colors means?
What is the efficiency ratio?
How can I solve this?
Solved by tony.ridley. Go to Solution.
please find attached an image that shows the error..waiting for your feedback
red symbol is because the member is either over capacity (efficiency ratio > 1.0) or deflection is above the limit you specified.
yellow symbol is what i mentioned before, the element slenderness is above what you have the maximum set to.
What about reinforced concrete combinations? i.e automatic load combinations conforming to AASHTO LRFD
