Dear All,
I am having a shed with the following loading
a) Dead load of structure
b) Wind Load +X direction
C) Wind Load +Y direction
The query is that while automatic calculation is done the following notice appear
Any reason why ? (snap ROBOT INSTA )
What does instability Type 2 means ?
But still when member verification is done everything is correct . ( snap ROBOT INSTA 2)
From help:
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-52C292E1-5C73-4FB1-B4E0-E5E8107777D-615.htm
In case of instabilities type 1 and 2 resultys are wrong.
If you want us check your model please send it.
There is no instability in this model.
Have you sent correct model?
Either remove releases on columns from the side of pinned supports or assing fixed supports there
