Incorporate Canadian Code CSA O86-09 for wood structure.
Robot Structural Analysis 2014 still does not contain CSA O86-09 Code for wood structure.  Is there a reason why Autodesk would not incorporate this?  Is the Canadian market too small?   Is there a timeframe for incorporating?
3 Comments
PatrickSt-Louis5310
For Canadian codes,
                      instead of the Wood design code  there is a lot of work to do :
   1- 2D  & 3D wind load generator
    2- Design of Deep beam
    3- check for node equilibrium in RC Frame
    4-Design of RC ductile wall
    6-Design of connections for CISC S16-09
    7-Implenntation of the Bridge vehicles
PatrickSt-Louis5310
I don't know what they are waiting to do that,  when regardind what the German software Dublal are doing actually, they have effectively implement the CSA-086-09nd the ANSI/AWC NDS-2012 code for the USA in their RFEM  software, in 2 modulus  called respectively a by  Timber CSA 8xx and TIMBER AWC 8.xx, with helpfull tutorials
https://www.dlubal.com/fr/timber-csa-8xx.aspx
https://www.dlubal.com/fr/timber-awc-8xx.aspx
philip.s
Status changed to: Gathering Support
prior status deleted, setting to default
